Demon guys what size -AN lines are you running.
Cruise-In IX Veteran
With this new summit discount out there I think I am going to try and do the line for my car. I want to order a fuel log and braided lines to run from the pump to a filter to the carb. What recommendations do yall have for size and fuel log?
Re: Demon guys what size -AN lines are you running. (Sigforty)
I ran -6 AN hose and fittings when I used the Demon. In fact, I replaced the entire fuel system with -6 hose when I switched to EFI.
(If you have to buy any hose ends I highly recommend Russell over Earl's. Both are decent quality but the assembly mechanism Russell uses is FAR superior. I can assemble 4 Russell hose ends in the time it takes me to do ONE Earl's.)
Re: Demon guys what size -AN lines are you running. (Cookwithvette)
i am running a 140 gal/min pump and 10 an line :auto:
[Modified by cruea79454, 4:20 AM 7/18/2003]
Here's a pic.......1/2 inch rejected aircraft line (cosmetic rejection) from the fuel cell. Bought an adapter from Jeg's to mate to the carb. I can get a p/n# if ya need it.
I went with the BG fuel log and 6-AN fittings to a filter and steel braided line to the fuel pump.
This is my motor on a test stand and picture number two was when I still had a mech. fan last year
[Modified by gkull, 12:45 PM 7/18/2003]
Re: Demon guys what size -AN lines are you running. (gkull)
It seems that -6 is the preferred choice. I talked to one of my bosses and he recommended -6 also.
I got to thinking about it and my fuel log might be an Earl's. It's hard to see in the picture but it's steel braided in the center for movement. The one you really need has quick disconnects to speed up jet changes
