Starter wiring harness
Does anyone have a wiring schematic for the starter for a 78 4 speed?
I have traced the wires, and found: clutch switch, coil, ignition switch, ground, and of course the cable from the battery.
I think I have them figured out, except for the coil wire. It has a large terminal end on it, (replacement used harness) and I thought this wire went to one of the smaller terminals onthe solenoid.
Please help :banghead:
Re: Starter wiring harness (rexx78)
Have you looked at:
http://www.corvetteforum.net/c3/tune...l/index6.shtml ?
Re: Starter wiring harness (wbarkley)
That is a good website, but it still doesn't show me enough. Does the coil wire go to the large terminal or one of the small terminals with the clutch wire?
