Centerforce DF clutch?
Senior Member since 1492
Is this the correct one? #DF735552, 11x1 1/8x 10.
http://store.summitracing.com/partde...57#largerimage
Re: Centerforce DF clutch? (1970 Stingray)
Len, What kind of tranny are you using, what is the spline count on your tranny?
If the spline count is right, I believe that is the right one, check to be sure though.
Re: Centerforce DF clutch? (69 N.O.X. RATT)
Thanks John, I'm using a rebuilt M-22 with a 10-spline shaft. I wasn't sure about the diameter either.
On another topic John, you're using the Lakewood scattershield aren't you? I think I remmber you posting about aligning it to the block?? :confused: Did you use their block locator kit?
Thanks
Thanks
Len - There is a good article in the current CHP that details checking runout on a Lakewood scattersheild. They do recommend the kit and to replace the dowel pins with their longer ones since the 2-piece scattersheild is thicker than the stock bellhousing. I'm doing mine now for my new tranny install. :smash:
Re: Centerforce DF clutch? (Marks69BB)
Thanks Mark, I saw that article. They've had some very timely articles for me recently. I'm glad I subscribed. :D
Thats the one I just put in... but an M-22 10 spline :skep: I thought they were 22 ? Use the CF TO and measure the distance to tip of Adjustable Ball stud. This is critical in the geometry. Also you will need a longer clutch fork Rod. I got 1.5" longer one Off C-2 I think...
Re: Centerforce DF clutch? (Gordonm)
I just went down to the gargage to check the splines....it's a 10.
Len - Since I had to buy a new clutch disc to fit my new Tremec's 26 spline input shaft, I have no use for the current 6 month old 10 spline CF DF clutch disc. If you're interested in saving some money by just buying the pressure plate new, email me and we can work a deal.
[Modified by Marks69BB, 9:45 PM 7/17/2003]
Thanks Mark, I'll keep that in mind but will probably go with new since everything else on this rebuild is brand new or recently rebuilt.
Len- I have this also. Good choice. Not a hard pedal at all!!!! No problem on my end as far as adjustment goes......
How is the motor coming along??
Bob :cheers:
Bob :cheers:
Re: Centerforce DF clutch? (Flareside)
Mark, did you try this yet? A friend of mine needed a new disc for his DF, and Centerforce wouldn't sell it to him. They only sell the clutch as a matched set. He was pissed! :lol:
Joe - If your friend can use my 10 spline disc and is interested, let me know. I bought a new clutch disc from Keisler.
Can't wait to hear how your TKO install goes, I have one on order myself.
