FI guys did you pull your socks off?
Re: FI guys did you pull your socks off? (zwede)
Happen to have any pics of your set up? My thoughts right now are to mount a filter higher than the pump to act as a supply buffer for fuel slosh if I can find the right design. I have a fram filter that I think draws the fuel from the bottom so it would have a built in reserve if you will of about a pint or 2.
Re: FI guys did you pull your socks off? (Fevre)
Yeah, I have some pics of the tank on the website. I love that tank. 21 gallon capacity and with the needle all the way on E I can still accelerate/brake/turn as hard as I want to without any air entering the fuel system. Stock tank was hopeless at anything less than 1/2 tank.
hey zwede im still using the stock tank with a pump right on the end of my sending unit,i can go as far down as 2 gallons in it then itll give me a problem around hard corners.
Re: FI guys did you pull your socks off? (patsnitrovette)
I've got my stock tank with a sending unit out of an '82, I hope I dont run into issues with this setup, a new tank would be spendy.
