mobil 1 synthetic 75W90 use in M20?
http://dallnd6.dal.mobil.com/GIS/Mob...f?OpenDocument
I have another post about muncie trans fluid change, is this the stuff to use?
Re: mobil 1 synthetic 75W90 use in M20? (74 vert)
:confused: somebody know?
:eek: I think I only drained about 12 oz or less before the drip started to stop. The drain has a magnet on it which was sludge covered (about 0.40 thick) and some bits of metal (biggest one about .08 X 0.04 X .01, the rest just grit) within the sludge, not much metal found. Wonder how long ago this stuff was changed. Anyway, should I go with this Mobil 1 (75w90) Synthetic Gear Lube?
[Modified by 74 vert, 7:26 PM 7/15/2003]
Brad, I put the same stuff in mine. I think it made the transmission shift a little smoother. So far I am pleased with the result. Maybe, Saturday we can go for a little ride in mine after the dyno runs.
Re: mobil 1 synthetic 75W90 use in M20? (Eddie 70)
Thanks, if been surfing on the computer with this Mobil one stuff sitting beside the computer waiting for a reply. My trans didn't have much fluid in it and is empty now that I've drained it. I guess if I drove it with that level very much longer, I would be going TKO quicker?
Saturday sounds good.
[Modified by 74 vert, 7:48 PM 7/15/2003]
To put the fluid in, you put it back in the top plug until you can feel it with your finger. Its kind of hard to do without a pump though.
Thanks Eddie. I used my suction pump in reverse, it took about a 1.5 quarts.
:seeya at the dyno. :cheers:
