Please explain Spark Plugs
I just found two boxes of spark plugs while going through my junk in the garage. They are R45TS and a box of R44TX. Which one is correct (best) for my bone stock, dual exhaust 1975 L82?
Re: Please explain Spark Plugs (Jim Shea)
44's are a colder plug. I also think the S in TS is for the extended tip. Someone else will need to chime in about the T and X portions :confused:
Good question Jim, I have always wonder about which plug to use. Anyone have spark plug users guide outlining cond to run diff plugs with plug cross references?
Re: Please explain Spark Plugs (Fevre)
I'd run the cold ones... then if they turn that wonderful light tan color... they are the ones... but i'd end up running both!
Dont waste em!!
Dont waste em!!
Here ya go:
http://www.acdelco.com/html/pi_plugs_ident.htm
I just went through this about a month ago. Here is the thread, hopefully you'll find some info that can help. I went with an Autolite 85.
http://forums.corvetteforum.com/zerothread?id=585121
