Check engine light - Help !!!
Cruising
Recently purchased a 82 CE with low milage. I notice that the "Check Engine Light" seems to come on only when doing highway speed (approximately 60 MPH). Does anybody know what is causing this.
Thanks
Thanks
Re: Check engine light - Help !!! (Jet Vette)
Could be any number of things. One of the first things I always check is the oil. Are you getting good oil pressure at highway speeds?
Re: Check engine light - Help !!! (77Dream)
The check engine light means that something to do with the emissions system has failed. This puts a code in the computer. You can do a quick search on this a pull the code very easily yourself with a paper clip (jumper wire) at the plug near the bottom of the dash. Autozone can read it for you too.
