Muncie Fluid Change?
How do you drain it? What kind of fluid should be used to refill? How much does it take to fill it? How do you check the level? How often should it be changed? :D
Re: Muncie Fluid Change? (74 vert)
There is a drain plug on the side of the case. Fluid changes depends on miles and what type of miles(racing for instance). I just replaced mine with synthetic. :cheers:
Replace with Synthetic ENGINE oil...mobil one is fine....that' what I did, and it shifted slick as a baby's butt.....like a newer internal rail type tranny.... I say it's not the location of the shifter, internal rails or external levers...i'ts all in the lubrication....
GENE
GENE
Re: Muncie Fluid Change? (mrvette)
I know these are Rookie questions, but how much should I buy? Don't want to make two trips to the store after work. Synthetic ENGINE oil...mobil one is fine, is synthetic oil graded?
[Modified by 74 vert, 8:04 PM 7/14/2003]
I bought three quarts, Mobil 1 Synthetic (75-90) for a little over $25. Don't know how much I'll use, hopefully some will be left over :skep:
