need help w/ A/C blower
i made my spacer and intalled my new motor ( a new one for a 95 corvette) and i can not get it to work. my original moter had two connections one was a smaller black wire that connects to a tab via a screw on the outer edge of the old motor and a heavy purplish colored wire that went to a tab that was made on to the motor. the new motor has two tabs built in. what goes where? i thought i tried all possible connections but i cant get it to work. i still want to be able to use my high-low-off settings. is it possible that i got a bad motor? if so should the store be able to test it?
Re: need help w/ A/C blower (ykp53)
I can't help. Have you tried to do a search in the archives. Put "blower motor" and you will get a bunch of past threads. If one doesn't help, maybe you can e-mail one of the guys who knows the answer.
Hope it helps :seeya
Re: need help w/ A/C blower (72GACRZR)
I Just IM'd you.
The two tabs are + and -. They are basically the same as the two tabs that you had on the original blower motor. You need to figure out which is pos and which is negative and then attach your original wiring exactly as they were but to the new terminals. Everything should work. If you put them backwards, the fan either will not work, or it may blow backwards.
If you have a battery charger, you can test the terminals and the motor on the bench and then label them. :)
Let me know how it goes. :)
