more tach circuit board talk...i recieved mine
i recieved my board and thought you all would be interested in seeing the papers that came with it...
i have been real busy so i havent installed it yet but here are the pics...
Re: more tach circuit board talk...i recieved mine (SIGNGUY)
Let us know how it goes. The install should be easy, just had mine out, all you have to do is pull the tach out...literally. Then unscrew the board and replace it.
Re: more tach circuit board talk...i recieved mine (C3 Shark Tank)
on those model tachs, the calibration was done on the circuit board.
How do you re-calibrate when just replacing the board?
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
My tach works but is a bit off (500 RPM off above 1500 RPM). Will a circuit board replacement fix this ?
Re: more tach circuit board talk...i recieved mine (BSeery)
i dont have the answers to these questions....yet...
as i said...i have been REALLY busy with remodling the house (swimming pool etc) but i plan on doing this in the next couple of days...
ill let yall know how it went and what it fixed etc...
