OT- Please help(if you can) with speaker wiring on my daily driver
Its a 86 Pontiac 6000. Im puttin new speakers in the dash. The factory speaker wires and speakers are not marked with + or -. The speaker terminals are marked A and B. Any idea which one is + and which is - ?
St. Jude Contributor
Re: OT- Please help(if you can) with speaker wiring on my daily driver (Jvette73)
I'd say turn your ignition/radio on & stick an idiot light into each wire to see which one has power going to it.
Re: OT- Please help(if you can) with speaker wiring on my daily driver (bgrice)
On a speaker you can test polarity by taking a 9 volt battery and connect it to the speaker. Whatever sp terminal that makes the speaker move out when connected to the + on the bat is the +.
As mentioned above, take a dc volt meter and test each sp wire with the red lead of the meter, ground the black lead. The + speaker wire will give you a couple of volts when on.
Re: OT- Please help(if you can) with speaker wiring on my daily driver (battsup)
the polarity of a speaker is reversible, unless if it something high end or a subwoofer.
Now, when a speaker is hooked up incorrectly with polarity reversed, sure it will play, but the quality of sound and frequency response suffers greatly.
Re: OT- Please help(if you can) with speaker wiring on my daily driver (LAvetteman)
[QUOTE]On a speaker you can test polarity by taking a 9 volt battery and connect it to the speaker. Whatever sp terminal that makes the speaker move out when connected to the + on the bat is the +.
Thanks for this idea. This will be the method i use. since the factory harness will only plug onto the speaker one way, ill test the speaker with a 9v battery to determine which side of the speaker is +, then the corosponding wireon the harness will be the + one. Great tips.
Ive tried the speakers both ways and ive alweays known that they will play either way. But I also know that there is a right way and a wrong way. The speaker cone should pulse outward sending the waves into the passenger compartment rather then pulsing inward sending the waves under the dash. I do notice a difference in bass when swapping the connections back and forth. I guess it would be obvious that the better bass would indicate its connected correct.
Thanks for the help
Thanks for the help
Test complete. The speaker terminal marked B on this vehicles dash speaker is the +. So the corrosponding wire on the harness must be the +. That was simple enough. Thanks again.
