Door glass hitting t-top bracket..
My 1980 driver's door window glass makes contact with the t-top attachment/alarm switch bracket on the rear pillar. This happens when I open and close the door. Can someone take a measurement or picture of the proper gap so I can make adjustments.
Thanks,
ric
Thanks,
ric
Re: Door glass hitting t-top bracket.. (Ric's80_4sp)
On a (possible) side note, how are your door hinges doing? It could very well be the case that your door hinge bushings are shot and causing the window pane to "fall" into the panel.
Do your doors droop down when you open them?
-Steve
-Steve
