anyone got pics of exhaust with headers
hi,
has anyone any pictures of how you've routed the exhaust underneath with headers??????????
i've got the headers, some 2 1/2 inch straight pipe and a couple of hedman turbo mufflers,
just wondering what the best way to route them is,
on my camaro i just have them from the collectors of the headers straight out the back, but it doesn't look like it will work on the vette,
thanks,
neil
thanks,
neil
Re: anyone got pics of exhaust with headers (camaroneil)
lots of guys have pics here, they haven't had time to post obviously
i have the same thing, headers, 2.5'' dual, and flo pro mufflers
you need some mandrel bent corners (about 45 degrees), and you will have to custom bend some of the pipes to line up through the frame rails properly
good luck!
good luck!
Re: anyone got pics of exhaust with headers (Gordonm)
thanks a lot guys, thats a great help,
at least there's light at the end of the tunnel,
gordonm, do they go through the holes in the crossmember???
neil
neil
Yes they go through the holes and the H pipe is after the cross member. I have a ball and socket on the H pipe so I can take the system apart. I have needed this about 4 times already.
Here's some pics of my exhaust system. The only thing I've changed since these pics were taken is the addition of dynomax Ultra Flow polished stainless mufflers.
