Is this a Bubba fix?
If I use black duct tape on my black snorkel duct hoses, (only on the ends)is that a Bubba repair? I tried buying a new one and that only lasted for 6 months! The openings on the end were never really big enough and had to be strechted so much that they frayed and the wires started showing.
Duct tape IS for ducts....I bought a matching color..........does this one make me a Bubba? Replacing it will only last 6 months! :smash:
[Modified by isosceles, 10:22 AM 7/12/2003]
Re: Is this a Bubba fix? (isosceles)
Well,the "general" idea of a Buffa Fix is :If you need to "Bubba fixit" `till you get home or get the right parts ,its :thumbs:
But if you drive around with it over year,then you´re in trouble :lolg: :cheers: :cheers:
But,I could be wrong :cheers:
....I bought a matching color..........does this one make me a Bubba? .....
St. Jude Contributor
Re: Is this a Bubba fix? (mapman)
matching color would be a bubba "lite". A true "bubba" fix would use the standard grey duct tape. :lol:
I'd say if the fix is not noticable to the general public and it doesn't fall off, spew stuff on the road or cause you to break down it is an acceptable bubba.
Re: Is this a Bubba fix? (bgrice)
That's a new one... a bubba "lite". :thumbs:
JB
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
To make it truly Bubba, you also have to make sure "the fix" is impossible to remove......in your case adding Super Glue to the tape for extra holding power......just a tip from your local Bubba Dealer...... :)
Re: Is this a Bubba fix? (standup)
Don't forget to wrap the "Special Deluxe Super Heavy Duty Acme Bubbifed Bailing Wire" around the ducts to hold them to the ends of the plastic houseings. Miss this step..and you risk your Total Bubbafication initiation into the Bubba Fix It Hall of Fame! :hurray: :hurray:
[Modified by 81' Corvette Guy, 4:10 PM 7/12/2003]
CI 4-5-6-7-8-9-10-11 Vet
St. Jude Donor '06-'07-'08-'09
Re: Is this a Bubba fix? (rexx78)
:rofl:
Bubba lite, I may have a few of those.
I know I do... :rolleyes:
Those ducts are still available from GM. The "real thing" will last much longer than aftermarket. I have the part numbers if you need them.
Re: Is this a Bubba fix? (paul67)
