Q-jet -> Holley Street Avenger. Ways to connect kickdown cable and throttle cable?
Application: 1979 L-48 stock Q-jet and manifold --> Street Avenger and Performer Manifold.
Hoses in place fuel line in place and everything is bolted down and ready to go. BUT....
Problem: Where can I mount the throttle cable? On the q-jet there was a bracket that bolted to the manifold under the carb, where the throttle cable could mount at, held in place. The kickdown cable is on the bracket with the what I believe is the cruise control unit. Anyone have any pictures of their setup? I'm a bit stumped. I understand how it works but where it mounts at to the carb and where I can hold the throttle cable in place is a mystery to me. Before I design and think of a plan I'd like to know how Corvette family members got their system to work. Thanks :)
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Ways to connect kickdown cable and throttle cable? (Phoenix79)
I think you are asking how to mount and hold the throttle cable and the trans kick down cable.
Get a bracket like this. The top one has a place to hold the throttle cable (top hole) and the bottom adjustable hole is for the trans kick down cable. There is also a loop for a throttle return spring. This mounts to the stud in the drivers side rear of the carburetor, the one that you mount the carb to the intake with.
CI 6-7-8 Veteran
Re: Ways to connect kickdown cable and throttle cable? (BSeery)
You will also need a stud to mount the kick down cable to the throttle linkage. I got mine from Edelbrock.
You can try either #8018 - Automatic Trans. Kickdown Stud — TH350 & 700R4
or #8009 Throttle Cable Adapter — Chevy (1977 & later)
Get the Edelbrock throttle bracket #8030 rather than the Mr. Gasket bracket. The Edelbrock piece is MUCH stronger.
