Update -clunk in rear
Well, I really haven't had too much road time to test the car, but I decided to change the diff fluid on my 79 and found out that there was only about 2.5 ounces in there. I added the GM additive and gear oil. I hope this cures all the clunking I had after the car heated up.....Any thoughts as to why there was only 2.5 ounces with no apparent leak????
Re: Update -clunk in rear (tabbruzz)
I had a little more than that in mine, but less than the filled amount should be. My side seals seap a little and I didn't know it until I changed the oil and filled it up to the drain plug level. Keep and eye on it, you might discover some leaks.
Re: Update -clunk in rear (isosceles)
