Should i swap my ZZ intake for Performer RPM?
I have to replace my intake gaskets this weekend and was thinking about a Performer RPM Air Gap. Just wondering if it would be worth the extra time & $$'s. Also, will this fit under my stock hood with a drop base cleaner?
Cruise-In IX Veteran
Re: Should i swap my ZZ intake for Performer RPM? (Steve81)
I plan on doing that eventually when I get the money. I also want to convert the stamped steel rocker arms to full rollers.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Should i swap my ZZ intake for Performer RPM? (Tominator)
I didn't think the ZZ intake fit under a stock hood? Is yours a stock hood?
The Air Gap would be great out here in 110+ land. But we would need to know the measurement from the carb. pad down to where the intake mounts to the block at the lifter valley.
