Alternator Mounting .... Double Hump Heads
As part of my donor motor buildup, double hump heads are being used. The problem is, my existing L-48 uses accessory holes in the heads to bolt the alternator bracket on, the "new" heads don't have these holes. This will obviously have to be changed. In addition, if possible,I would like to mount the alternator on the passenger side to balance out the appearance under the hood, and to allow me easier access to the power steering pump. Is there any one out there with these heads, or that has done this change that can give me the options, part #'s for what it is I need to purchase?
Thanks.....
Michael
[Modified by 75Rag, 4:55 PM 7/10/2003]
Thanks.....
Michael
Re: Alternator Mounting .... Double Hump Heads (75Rag)
If you put the alternator on the other side, won't it be spinning backwards :skep:
A '68 Corvette smallblock setup the bottom of the alternator bolts to the front of the driver's side exhaust manifold. :yesnod:
Re: Alternator Mounting .... Double Hump Heads (Paul Borowski)
[QUOTE]If you put the alternator on the other side, won't it be spinning backwards :skep:
OF course it will, but i'ts easily cured, just turn the belt around...... :D
GENE :thumbs:
GENE :thumbs:
Michael
[Modified by 75Rag, 5:41 PM 7/10/2003]
Re: Alternator Mounting .... Double Hump Heads (Fevre)
Can the heads be tapped with needed holes?
If I can't locate the parts required, I'll have them fabbed.
Hans
Re: Alternator Mounting .... Double Hump Heads (Wrencher)
There 'ya go! I've seen them mounted low like the P/S pump, and high over the waterpump, but not on a vette.
Hans
http://www.chevyhiperformance.com/fe...ehicles/86083/
[Modified by Fevre, 1:00 PM 7/10/2003]
Jegs sells a bracket made by Dynomax that will allow you to mount your alternator on the drivers side. It is described as "GM Early Front Bracket" and is their item no. 289-88301. You use the stock '68-'71 brackets and this bracket takes the place of the manifold mount. Here's some pics of the install in my '73.
This won't help you mount on the passenger side but it beats fabricating something.
Re: Alternator Mounting .... Double Hump Heads (Kid Vette)
Bravo! Thanks Mark :thumbs: That'l do the trick, maybe they make a "mirror image" one for pass. side apps.
Thanks again.
Michael
Thanks again.
Michael
