I am having problems with my 71 headlight switch
2nd Gear
I broke my headlight switch about a month ago. I ordered a new one and replaced it. I discovered an vacuum leak coming from the switch. I then ordered a second one and the same thing happened. The original worked fine except I the electrical plug-in connector and tabs broke. The vacuum lines are hooked up correctly but I still ahve a vacuum leak when I turn on the switch.
What am I doing wrong ????
