Multi spark ignitions: Do they offer any performance gains in street machines? ie, MSD6A ?
3rd Gear
I see these often in street vettes but never was sure if they really do much at lower RPMs. I know some timing lights will not work with them.
Re: Multi spark ignitions: Do they .....
It all depends. For high compression,nitrous and blown engines it is very helpfull, in a normal engine - about all you will see is improved starting, idle, and sometimes throttle response. If you do see a benefit, it is most likely that its actually covering up for something else thats wrong.
By themselves, little to no performance improvement.
Re: Multi spark ignitions: Do they ..... (fauxrs)
:iagree: A well tuned stock ignition on a stock motor will see no improvement. If big cams and nitrous or blowers are used a CD box will help improve it. I put one in and it starts much better and idles better. It also has a rev limiter which I have come up on many times so it might have saved a few parts along the way. A well built HEI unit is tough to beat though.
Re: Multi spark ignitions: Do they offer any performance gains in street machines?
No performance gains? :confused: You guys must have forgot to install your stickers. :D
I just installed a Crane unit in my 89 Formula and I swear it now starts harder, with a MSD 6A in my vette along with ProBillet dist it starts immediately.
ON a DPFI computer car you will never see any differance....
BUT on an older car with a rich carb at idle, yes, they help smooth out the engine and burn the fuel....
that's about it.....
OH, don't forget at about 3000 rpm's the extra 'sparks' disappear, so there is NO advantage at higher rpm's/power
GENE
GENE
Re: Multi spark ignitions: Do they offer any (tshort)
They work just fine with timing lights, BTW, I use my dial-back Craftsman all the time with my MSD 6AL. It does start much easier, idles smoother, great off-idle performance. In my case my distributor was somewhat worn so I replaced it with a Pro Billet MSD unit so high RPM performance is MUCH better as well. From what I understand most HEI units are about done around 4500 RPM. I have an Accel module, cap, rotor, and coil on my 454 Suburban and it pulls well to 5000 or so where the tranny shifts.
Jeff
Jeff
Re: Multi spark ignitions: Do they offer any (mrvette)
The extra spark disappers but the much hotter spark stays there. A points dist and stock coil cannot generate the spark that a CD box can at any rpm. If you are pumping in extra fuel or air (nitrous, blower or turbo) it can "blow" out the stock spark. With a CD ignition the spark is much more powerful. Mine never misses a beat to 7000+ rpm and I trigger my Crane HI6 box with a set of heavy duty points.
GENE
GENE
