oriface tube inside the Evaporator in a 76 AC shark
Old 07-09-2003, 12:50 PM
Packy76
Packy76's Avatar
Default oriface tube inside the Evaporator in a 76 AC shark
Is there suppose to be an oriface tube inside the Evaporator tube in my 76, Im currently rebuilding and didn't see one in the AC unit anywhere, if there is on suppose to one where can I get it? :confused:
Old 07-09-2003, 03:01 PM
azswede1960
azswede1960's Avatar
Default Re: oriface tube inside the Evaporator in a 76 AC shark (Packy76)
On my 1980 it is in the small tube from that runs down vertically next to Evaporator core box & Dryer. It has a nut fitting that I took apart and pulled out the orifice.
If you find it, let me know if it was "long" side of orifice down or "short" side down
Tom
Old 07-09-2003, 05:40 PM
Kevin_73
Kevin_73's Avatar
Cruise-In X Veteran
St. Jude Donor '09-'11
I am pretty sure that the General used the VIR system from 73-76, and I know that my 73 does not have a orafice tube in the system.
I would assume that if your 76 has a VIR instead of seperate valves and a receiver/dryer you probably don't have a orafice tube.
Hopefully someone who knows that year better will chime in.
To oriface tube inside the Evaporator in a 76 AC shark
Quick Reply: oriface tube inside the Evaporator in a 76 AC shark
