Should I paint an aluminum radiator?
I know this question came up before but I haven't seen a definitive answer. I have just ordered a DeWitts aluminum radiator and I noticed on their web site that they show all the aluminum radiators with a natural finish. I have always heard that flat black radiates heat better. So, do I paint my new radiator flat black? :confused:
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Should I paint an aluminum radiator? (Kid Vette)
No. I would think bare metal would radiate heat better than a metal that has something covering it. I think the other's are painted to provide corrosion protection.
Re: Should I paint an aluminum radiator? (BSeery)
Leave aluminum bare flat black is for other metals I believe
No do not paint it. Bare aluminum will dissipate heat much better than if it were painted (help keep things cool). Personally, I wouldn't want to paint it anyway, my bare aluminum radiator looks pretty snazzy in my opinion.
Re: Should I paint an aluminum radiator? (wayne_69_427)
My DeWitts came painted. It is an aluminum reproduction though, so that may have something to do with it.
Re: Should I paint an aluminum radiator? (Eddie 70)
First Aluminum has to be primed or anodized (SP?) for paint to stick to it. Second, there is a special radiator paint that sprays on thinner than Kyrlon etc. I have heard that regular spray bomb paint may decrease the efficiency of the radiator because it goes on thicker and decreases the size of the air passages between the fins. I left mine natural and like stated above I think it looks snazzy.
Re: Should I paint an aluminum radiator? (theandies)
Black both absorbs AND radiates best - but not the way to go - since the paint
clogs up the air passages. Leave it raw.
:seeya
what would anodizing do to the heat dissipation qualities?
Re: Should I paint an aluminum radiator? (Aflac)
Seems like it would help. In How to Hotrod Small-block Chevys they state "ALCOA compares an as-cast surface with one which has been black-anodized to a depth of 1.7 thousandths. The black surface is more than ten times better in heat-radiating ability than a plain cast surface."
Anybody know how much it would cost to anodize a radiator?
[Modified by Kid Vette, 9:02 PM 7/8/2003]
Re: Should I paint an aluminum radiator? (bence13_33)
-bZj
Re: Should I paint an aluminum radiator? (Down8)
Just to put some closure to this thread. I contacted DeWitts for their opinion and this was their reply:
"I don't think it would have an effect either way. We thought about offering this option but decided that it wouldn't work because everytime someone touches a radiator it gets some fin damage."
Point well taken. Not so sure I would want to put a $500 radiator in the hands of an anodizer either. Guess my radiator will stay that snazzy aluminum color. Thanks for everybodies input. :thumbs:
C6 the C5 of tomorrow
About anodizing think about this...
Anodizing basically turns the aluminum into aluminum oxide ( ceramic ) very brittle... I would be afraid of stress cracks in the radiator after a while
St. Jude Contributor
Re: Should I paint an aluminum radiator? (427V8)
