Difficult shifting 4 speed ........
This just started yesterday, wasn't gradual at all. On my way home from the Niagara On The Lake Show ..... the old girl decided she didn't want to go into any gear. I have to shift very "aggressively" to get a gear change. What should I look for? Any tests I can do to give you more info?
Michael
Michael
Re: Difficult shifting 4 speed ........ (75Rag)
Obviously, it is either one of two things. The transmission or the shifter linkage. As a start I would probably inspect the shifter linkage and make sure it is adjusted properly. If there is no obvious binding etc., I would disconnect the linkage from the transmission and see if the shifter rods move pretty freely. If they are binding then you have probably found your problem. You will need to remove the shifter and rebuild it. If the linkage moves freely then you may have worn syncros or shifter forks or some other problem. If it were me, I would pull the tranny, remove the side cover and investigate.
Re: Difficult shifting 4 speed ........ (BB68Vett)
I'm sure hoping it's the linkage. I tried double clutching and no difference so I don't think it's the synchro.
Might have to start hunting down a 5 speed, anyone got suggestions there?
Most likely it's the shifter linkage or the clutch. A clutch that is out of adjustment will make it difficult to shift gears. Was it wanting to grind the gears? If not, it's the shifter linkage. The rods could be binding up or the bolts that hold the linkage in place could have loosened up. It has happened to me before.
The black rubber thing on the left is what's know as a 'clutch pedal'. Tou will find that depressing that before you attempt moving the shifter will improve performance dramatically..... :lolg:
Re: Difficult shifting 4 speed ........ (bence13_33)
Re: Difficult shifting 4 speed ........ (SuperFast80)
I agree that it could be the clutch linkage or the shifter linkage. If it changed suddenly I would suspect the pivot ***** for the bellcrank. Also, check the oil level in the transmission. Mobil One synthetic makes an old (or new) 4 speed shift really smooth. It's worth changing to it even it that's not the problem.
When i think of something that might change with heat or a long drive i would suspect the clutch. Check the adjustment. You seem to indicate that it was in all gears which also leads me to think there is still pressure on the drive train. I would think double clutching would improve a sycronization problem. Good luck.
Re: Difficult shifting 4 speed ........ (adamdinat)
Thanks for the help guys! I've made note of all your comments and I'll check the obvious stuff first.
Thanks again!
Thanks again!
My push rod (clutch to cross shaft) broke this weekend. After putting it back together temporarily I noticed a difference in the clutch, and shifting. I think the rod was bending, finally work hardened and broke. It broke at the threaded end. There's not that much material there. Of course mine is 35 years old. Got a new one from the general today for $11.84.
Worth a look see.
Worth a look see.
Try getting under the car and spraying the linkages with white lithium grease. Worked for me with the same problem. :thumbs:
Re: Difficult shifting 4 speed ........ (DaddyO)
I'll bet you a beer its the clutch no fully disengaging. Linkage wear, clutch pivot stud wear could be issues as well as it might need some adjustment.
Re: Difficult shifting 4 speed ........ (MikeC)
I'm going to lube the linkage first and try it out, then move on to adjustment, then ... I guess it's inside we go....
MikeC, I'll buy you a beer anytime you get down here!!
Just be careful after adjusting your clutch linkage..... it makes your clutch pedal a very different beast. The points where your clutch disengaged and engaged and the rate that the clutch will grab will be different. This means your leg will have to re-learn the clutch(I once spun the tires out of my garage because of this..... almost took off the sideview mirror doing it.)
Just an update guys ...... the reverse lock out & linkage was hanging up, making it difficult to get any forward gear ...... cleaned and lubed ... all OK.
Thanks for the help. BTW, changed to synth gear oil too.
It's good to hear that you fixed it. How does it shift with the new synthetic?
Re: Difficult shifting 4 speed ........ (burners)
Right now I can say it's never been better, BUT, having said that, I'm not certain if the greatest gain came from cleaning a lubing the mechanism, or changing to synthetic.
