How Much A/C Compressor 'drag' with A/C turned off?
I'm wanting to guesstimate the effects of removing the belt from my A/C compressor. It barely cools the car and I rarely have a need to use the A/C as the car only sees duty with the tops off or on with windows down.
What HP 'savings'/gain would I realize by removing the A/C belt? Pros/cons?
Re: How Much A/C Compressor 'drag' with A/C turned off? (TedH)
With the A/C turned off it is just a freewheeling pulley. Maybe one to two hp saving by not having to move the mass of the pulleys.
tom...
tom...
Re: How Much A/C Compressor 'drag' with A/C turned off? (Tom73)
Thanks for the info. Will leave the belt on.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
tom...
tom...
Re: How Much A/C Compressor 'drag' with A/C turned off? (BSeery)
Also, unless you turn the AC on every now and then the compressor will seize. A AC system that "barely" cools the car is still better than one that doesn't work at all. :yesnod:
Cruise-In III Veteran
FYI----the a/c system on my 72 was a POS. The belt was on the compressor and turning, but I took EVERYTHING off. I felt no difference in power at all.
