Engine Plate & Shifter Pattern on Trim Plate
For a '69 trim plate, can either the engine plate or the shifter pattern be removed?? I assumed so because I see ones for sale in the catalogs. How do you remove them?
Re: Engine Plate & Shifter Pattern on Trim Plate (69stingray)
The trim plate is just glued on. On my '73 the shifter pattern is also glued on, so would assume the same for yours.
tom...
tom...
