How do I get Weld Pro Stars to fit?
Cruise-In VII Veteran
St. Jude Donor '07
Got a smokin good deal on some Weld Pro Stars Skinnies and rears, but they don't clear the calipers. Looks like it need about 3/4" to 1" clear caliper. What do I do?
Re: How do I get Weld Pro Stars to fit? (Budman78)
you would have to put longer studs , shave the calipars, and use a spacer. or you can do as oliver is doing and get the wheel adapter.
I used 1/2 spacers and longer studs on the front,and a 1 1/4" wheel adapter on the back for the DragLites.
