NAPA Water Pump
NAPA Water Pump
Does anyone know if the NAPA High Performance Water Pump (Item#: NWP55984H) is aluminum or not? Also, is this a good option for an L-48 that's soon to be rebuilt to around 300HP?
Re: NAPA Water Pump (Tonwoo28)
Just make sure it has a 3/4" snout to match up with your water pump pulley or you'll have to get a new pulley, must are 5/8" except for vettes and trucks.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
It should be the same as stock casting. Again, make sure it's a "short" style with a 3/4" shaft.
