Body seams on a 73
Body seams on a 73
On a 73 where are the factory seams where the body pieces are grafted togeather? Im mainly interested in the rear half of the car. A link to a photo showing all the pieces would be great.
A CI-6 Car Show Winner
Re: Body seams on a 73 (Jvette73)
You could go into vanacor's site and look at the replacement panels, you should be able to get an idea that way.
http://www.vanacorvette.com/
You can also see where the seams are because there are bonding strips inside the body, many are visible from underneath. Maybe someone else will post here with drawings, but I don't know of any.
Don't know if this helps or not, but here is a picture of my 75 after I stripped it down to the fiberglas.
The pink areas just below the lip of the body lines is what I was told is the factory body filler of the seams. Didn't see any other than down each side of the car and a few areas where a nick or crack might have been.
Click on the picture to enlarge it
[Modified by Rich's75, 11:32 AM 7/6/2003]
