Anyone here sprayed a gelcoat to seal their vette up before painting ?
I,ve read Lars paper and will probably go that route as my car only has a few minor areas that need cosmetic repair not structural. My car is down to bare fiberglass ...I,m still doing some final sanding in all the edges/hard to reach places. ....Any tips on filling in the rear luggage rack holes ? I perfer not to have one . Thanks .....
I ask the gelcoat question as I heard it was the best thing to assure that nothing bleeds through after final paint....Its was at a restoration class during the 50th in Nashville by NCRS..
Re: Anyone here sprayed a gelcoat to seal their vette up before painting ? (White 68)
i did it to mine,will i ever do it again NO,i stripped it all the way down to bare glass,but it sat outside for a year then got back to it again.The errant strands of fiberglass were stickiing up everwhere and the glass it self was in pretty bad shape so i gel coated the entire car,then preceded to block sand it out for a month,after i was done i was happy with the results,very straight.I also gelcoated it in blue.I had one spot on the drivers side door that before i gel coated it would always come back,it was oil from inside the door when i sprayed the linkage it soaked through the glass and through the primer,i preped it and then gelcoat ,it never came back.
[Modified by patsnitrovette, 6:32 PM 7/5/2003]
St. Jude Donor '09
Re: Anyone here sprayed a gelcoat to seal their vette up before painting ? (patsnitrovette)
I used Ecklers spray gelcoat over the bare glass just for insurance, but like stated above never again. The stuff has a wax-like substance on the surface after it cures that's a pita to remove before you can get to blocking. I have to say tho it seems to have done it's job.
The modern two part primer sealers should be a better way to go imo.....
Mike :cheers:
Mike :cheers:
Re: Anyone here sprayed a gelcoat to seal their vette up before painting ? (yellow 72)
Use the correct type gelcoat and PVA and it will not sand so hard.
Re: Anyone here sprayed a gelcoat to seal their vette up before painting ? (wombvette)
yeah i used a mold release formula from a marine supply -evercoat makes it worked great,sprays on like a wax then when you know its dry underneath just wash it with soap and water comes right off.
I used a epoxy sealer, DP40 I believe from PPG. Someone told me that the sharks weren't Gel-coated anyway.
Cruise-In IV Veteran
Re: Anyone here sprayed a gelcoat to seal their vette up before painting ? (Roadster71)
I used K36 on my car. came out great.
About the luggage rack holes.. your better off leaving them there and putting a rack back on.. you'll never get the holes to disappear. TRUST me on this one. when i painted mine, primer and basecoat it looked like the holes were sealed up and you wouldnt be able to see. as soon as i put the clear on, 6 rings showed up on the back deck. damn was i pissed to see that :mad
