need help with shock bracket
How do I get the shock bracket out. I can't seem to move it and I don't want to break it. I'm trying to replace the bushings. Thanks for your help. I don't know what I'd do with out everyones help
Vince :banghead:
Vince :banghead:
Re: need help with shock bracket (vincevette)
Soak the assembly good with penetrating oil. Go to the hardware store. But two nuts the same size as you castle nut. Screw them on the bolt tightly together leaving the bolt with a small amount of protection from the nut and hammer away. It will come out eventually.
