Yousa the Summer is here!
Yesterday I got to fight the worst traffic jams of the YEAR with the tops off the Vette in 90 degree heat :mad :smash: Took me two and a half hours to get home on a drive that is usually 30 to 40 minutes. :rant:
The stroker ran 200 to 205 in traffic and I'm wondering how warm she'd have been if I had connected that A/C when I put the motor in. The radiator is a new high-fin-count unit from a local shop using a Modine core. In regular driving it runs 190 but even when I got finally rolling at normal speeds yesterday It never cooled down below 200. Now, I know that's not hot - so don't misunderstand me - but I'm thinking that if and when I do get off my **** and fix the A/C, that may put her up to 215-220 ... which is a bit on the hot side for my liking. I'm using the OEM fan and clutch (and yes the clutch is good-still grabs a WHOLE lot of air) but after yesterday I'm rethinking this.
Any takers on this ???? I have indeed verified the accuracy of the temp gauge a few times using a Snap-On radar gun. The thermostat housing and the radiator core both show to be within a very few degrees of what the dash gauge shows so I do indeed trust what it is telling me.
:flag
Happy Fourth!
[Modified by SanDiegoPaul, 9:52 AM 7/4/2003]
:flag
Happy Fourth!
St. Jude Donor '09
Re: Yousa the Summer is here! (SanDiegoPaul)
Yeah, we were at 90 degrees yesterday morning at 7am.... :mad
I have driven my CE in 115degrees and will do it again tomorrow, to get to the show. I see up to 220 with the AC on, and oil temps just below 250. I just stay out of the pedal and keep good oil in it. Those temps shouldn't hurt anything, I see them towing my 5th wheel too.
St. Jude Donor '09
Re: Yousa the Summer is here! (battsup)
Sure, the hitch was easy right between the t tops. it was getting the dually's mounted....that was the hard part.... :p:
Re: Yousa the Summer is here! (Desertdawg)
wow that's hot. My carb doesn't even run worth a crap in traffic with it at 200!! :smash:
Actually, I've been tempted this Summer to install the OEM air cleaner assy with the snorkels ... and hope it does not cut down airflow too much. What I lose in airflow may be enhanced by the cooler air.
St. Jude Donor '09
You will see a nice benefit to cooler air, I can't run my open element K&N on my truck during the summer... Way to hot under the hood....
St. Jude Donor '09
Ok! Home from the show, I drove to Phoenix at 2 pm. the outside temp as probably about 114, the vette ran around 210 (thats were the aux. fan kicks in), and oil temp was between 240 and 250 depending on if I got on it or not.
Didn't get to many chances to idle in traffic but when I did the oil started to cool off, (230) and the water stayed about the same.
