exhaust leaks
exhaust leaks
i have header gasket that is tore on the driver side. would this cause my car to idle like crap? also what are my options for fixing it, whats the temporary solution, and what gaskets would you recommend to fix it properly.
[Modified by ykp53, 12:36 PM 7/3/2003]
Re: exhaust leaks (ykp53)
Yes, I think the torn gasket would make the car idle poorly. To fix it you have to put new gaskets and I recommend the Percy's aluminum gaskets. You can get them from Summit.
Re: exhaust leaks (vettfixr)
The last time I went to drag strip I blew a header gasket. I replaced them with copper ones from Mr. gasket (40 bucks :eek: ) and have not had any problems since. These are really thick and when I removed my header last weekend to replace a motor mount the gasket still looked like brand new.
