YE-HA the Air/Fuel meter works
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19
This is probably the best one thing I have done to help get better performance out of the vette. No more guessing if the mixture is correct and if the vette is running the best it can.
I welded the O2 bungs on and installed the sensors then I hooked the meters up adjusted the idle at 14.7:1 and went for a ride. Cruising the mixture is off the scale lean and soon as I hit the go peddle it goes full rich. I will be locking out the secondary and checking the primaries to see how for out they are and make adjustments. Once I get them set I will unlock the secondary
and tune them.
I can’t stress enough how this is the ultimate tuning tool it takes the guess work out of tuning the carb. For what it cost me to build it is probably the cheapest thing I have done.
Lasse
The readings on my two meters are as follows.
1 .11 1 .18
2 .22 2 .28
3 .33 3 .38
4 .44 4 .48
5 .55 5 .56
6 .66 6 .66
7 .77 7 .76
8 .88 8 .86
9 .99 9 .96
10 .1.10 10 .1.06
The last led on both meters will not light because the voltage required is to high it seems the 330 ohm resister is not enough I will be replacing it with a larger one to get the #10 led voltage down a little so it will be in the same range as the O2 sensor (needs to be 1.0 volts or just bellow).
Neal :hurray:
[Modified by chevymans 77, 10:35 PM 7/2/2003]
[Modified by chevymans 77, 10:37 PM 7/2/2003]
and tune them.
Lasse
1 .11 1 .18
2 .22 2 .28
3 .33 3 .38
4 .44 4 .48
5 .55 5 .56
6 .66 6 .66
7 .77 7 .76
8 .88 8 .86
9 .99 9 .96
10 .1.10 10 .1.06
Neal :hurray:
C6 the C5 of tomorrow
Re: YE-HA the Air/Fuel meter works (Schmucker)
Did you put the o2 sensors in the collectors?
I tried puttin them in the headers but with my cam they get a real messy signal :U
Schmucker
The O2 sensor sends out a voltage signal calibrated to operate in a range with 14.7:1 being near the center. The meter is a simple voltage meter that instead of displaying numeric values it lights up LED’s each LED represents a given voltage from 0.0 to 1.0 (lean to rich) if the meter is calibrated correctly 14.7:1 will be near .5 volts which will light up half or 5 LED’s. Hope this helps.
427 V8
The cam may mess up the signal at idle due to overlap but once off idle it should clear up. You could possibly dampen the signal more, this may slow the fluctuations from the sensor. I do not have headers, but Lasse has recently installed his O2 sensor at his collectors and it appears to work fine.
Neal
[Modified by chevymans 77, 6:58 AM 7/3/2003]
427 V8
Neal
Re: YE-HA the Air/Fuel meter works (chevymans 77)
Neal - Good, really balanced figures btw the meters. Have you measured the two engine sides at the same time and compared the balance? It would be nice to hear how much they can differ. :cheers:
Schmucker - I used this graph to translate the led's to A/F ratio:
Value of led # in my case..
427 V8 - The leds on my meter jumps syncronized with the sound on idle (2-3 leds up and down), but on the road the leds lits steady on the values. You have my cam figures in the sig. I mounted the sensor right after the collector (~1 1/2 foot in front of the crossmember) and attached the A/F meter ground to the collector clamp and chassi ground. (one wire sond).
:thumbs:
:thumbs:
Re: YE-HA the Air/Fuel meter works (427V8)
A/F meters are great!
i never would have guesed my carb back barrels were 42% too rich. Only problem now is i use so little gas, i worry about it getting stale. :p:
427V8- did u have a ground wire direct to the sensor? i've not read about any cam causing a problem.
i get lean readings within 2 seconds on a cold start, if i don't pump it enough, non-heated sensor.
Re: YE-HA the Air/Fuel meter works (Lasse)
Lasse
I mounted both meters and went for a ride. Both meters mirrored each other while cruising but while adjusting the idle I was able to separate the readings from side to side. The adjustment would affect both sides but it would alter the side I was adjusting more then the other.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
what sensors are you using? (brand and part number and where you got them).
2 or 3 wire ?
2 or 3 wire ?
Re: YE-HA the Air/Fuel meter works (BSeery)
BSeery
They are Bosch sensors I bought off of e-bay for $15.00 I do not have the part #'s with me but I will post them as soon as I get home. They are the single wire sensor. You should be able to pick these up at the local parts house for $20.00 new.
oooh drool .. This sounds like an efficent cool way to fine tune in your machine. I personally am tired of my 8MPG w/ my 454. PLease pose more info. mabie a how to?
thanks
chad
thanks
chad
Chevymans
Mine were mounted right up next to the heads on the primary pipes, I think the fule is still burning there !
I haven't had time to move them to the collectors yet, but plan on it as soon as I finish the other 15 projects ahead of it!!
71'AirStrike - We had a topic of the construction two weeks ago. Check out: http://forums.corvetteforum.com/zerothread?id=584319
We have follow http://www.markvanderkwaak.com/dbbp/tech-tips/mm.html building scheme.
CI 6-7-8 Veteran
Re: YE-HA the Air/Fuel meter works (71'AirStrike)
thanks
chad
thanks
chad
I think these would be very similar to the Nordskog brand meters sold through Summit or Jegs.
I think I need to go with a heated sensor since I have mine in the collector of my headers.
[Modified by BSeery, 1:34 PM 7/3/2003]
Tuning without an A/F meter is like flying a plane blindfolded! :cheers:
newbies see sig. link
CI 6-7-8 Veteran
Re: YE-HA the Air/Fuel meter works (Matt Gruber)
[Modified by BSeery, 9:17 AM 7/4/2003]
