Heater core done, it was pretty easy.
Old 04-06-2003, 08:15 PM
Fastguy
Fastguy's Avatar
St. Jude Donor '03-'05
Default Heater core done, it was pretty easy.
Whoever wrote that huge "pull the dash out" article was a friggin' crackhead.
You don't pull the dash, instead, pull the passenger seat.
Pull the hush panel, drop the ECM and the door control module.
Remove the support bar going from the door pillar to the dash.
Use a 7mm to take the cover off the heater box.
Pull the cover, unbolt the core, re-install.
Drink beer and laugh at webpage showing guys pulling dash.
[Modified by Fastguy, 8:17 PM 4/6/2003]
Golferdad (05-18-2023)
Old 04-06-2003, 08:42 PM
Ramjet
Ramjet's Avatar
Default Re: Heater core done, it was pretty easy. (Fastguy)
:lol: :lol: :lol:
Old 04-06-2003, 09:16 PM
AGENT 86
AGENT 86's Avatar
Tech tip time!! :cool: :cheers:
Old 04-06-2003, 10:06 PM
Steve85
Steve85's Avatar
Cruise-In V Veteran
"Whoever wrote that huge "pull the dash out" article was a friggin' crackhead."
are you referring to...
http://forums.corvetteforum.com/zero...143297#5143297
Old 04-07-2003, 12:10 AM
Fastguy
Fastguy's Avatar
Default Re: Heater core done, it was pretty easy. (Ski2Tee)
Actually, no this magazine article here. http://temp.corvetteforum.net/c4/jonm//c4heater01.jpg
But after looking at what you did on your page, I'm assuming you read the article.:(
I started disassembling the dash and then decided to check my Haynes manual. Oddly enough, its also said to remove part of the dash, which is totally uneccessary. After reading what had to come out, I just decided to feel around and noticed there are really only two 7mm that are tricky to get at but not impossible. A 1/4 ratchet with a short extension and it was no problem. I have been putting this off since Sept because it was made out to be such an ordeal by everyone. Not trying to slam anyone that has gone the long route, I just want to let people know there IS another way to do it and just because some magazine printed an article, doesn't make it gospel.
[Modified by Fastguy, 12:16 AM 4/7/2003]
[Modified by Fastguy, 12:20 AM 4/7/2003]
Old 04-07-2003, 07:51 AM
Vic'89
Vic'89's Avatar
Thanks for the tip.
It's always good to post different experiences.
Vic
Old 04-07-2003, 12:32 PM
War Machine
War Machine's Avatar
Location: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
:lolg: :lolg: :lolg:
Thanks for the tip! :cheers:
Old 04-07-2003, 02:11 PM
65Z01
65Z01's Avatar
Thanks much for the tip; with over 120k miles I know I'm getting close too.
Old 04-07-2003, 03:18 PM
Joshua S. Smith
Joshua S. Smith's Avatar
Yeah, thanks alot for the tip. I got over 150k on my '85, and the works when I got over a bump. Course, when I go over antoher bump, it stops, etc.... :smash:
I'll have to print this out for when I do replace my heater core. :)
Old 04-07-2003, 04:54 PM
Steve85
Steve85's Avatar
Cruise-In V Veteran
No, I didn't read that article. I was replacing the dash skeleton and di the heater core on the way. I feel sorry for any one following the article. Even with all that I removed the core is no more accessible than what you did. Good work!!
Old 04-08-2003, 01:32 PM
Fastguy
Fastguy's Avatar
Thats cool, its just that whenever anyone asks about heater core replacement, that article gets posted, and its a stupid article written by stupid people. Unless you are over 8 feet tall or weigh 400 lbs, there is no reason why you can't remove the seat and lay on your back to drop it out.
Old 04-08-2003, 04:36 PM
91drptop
91drptop's Avatar
Man am I glad you posted this article! I have been needing to replace my core for 6 months now and was dreading the weekend of being upside down with the dash apart. Thank you. I will try to take some pictures when I do mine using your method. :hurray:
Old 01-03-2013, 08:24 AM
cesmachines
cesmachines's Avatar
Default Heater Core Replacement
Thanks for the tip. I just started smelling antifreeze in the driver’s compartment of my ’87 and I thought, oh no, the heater core! I’ll check out your procedure and report back.
Old 01-03-2013, 09:13 AM
Kmcoldcars
Kmcoldcars's Avatar
This thread is from 2003. Almost 10 years old.
Old 01-03-2013, 12:21 PM
desertmike1
desertmike1's Avatar
age doesn't change the procedure..
Old 01-03-2013, 01:09 PM
383vett
383vett's Avatar
Received 1,550 Likes on 1,048 Posts
The mods will though.
Old 01-03-2013, 01:34 PM
ch@0s
ch@0s's Avatar
Or the rules
To Heater core done, it was pretty easy.
Old 01-03-2013, 02:00 PM
3D87C4
3D87C4's Avatar
True...but here's my gratuitous post so it's in my subscribed list.
Old 01-04-2013, 04:06 AM
Keystring
Keystring's Avatar
Me too...
Old 01-04-2013, 09:44 AM
dizwiz24
dizwiz24's Avatar
sometime people need reminded that 'the old days' (of pulling the dash) werent always so good.
My favorite part was the procedure about sitting back and drinking beer while laughing at the people that pulled their dash apart.
Quick Reply: Heater core done, it was pretty easy.
