knock indicator and shift light.
I made a simple test.
A 1k resistor in series with a large high intensity LED.
I connected one side to the 12V feed to the ESC module and the other to the output wire.
( click the pictures to enlarge )
And a short video of me tapping at the exhaust. You can see the LED flashing when a knock is detected.
http://jobyteknik.homeip.net/corvett...r/MOV08144.MPG
I made two LED's with resistors and cable. I installed them in the dual pillar pod. I am going to use one as knock indicator and the other as shift light.
[Modified by JoBy, 4:00 PM 4/2/2003]
Re: knock indicator and shift light. (HighHopes85)
Cool idea...
You mentioned shift light--what are you using for the trigger?
Re: knock indicator and shift light. (Justme)
I switched to 730 ECM and used a jumper aroung the ESC Module. How could I make one for my car?
