Speedometer light replacement
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
I'm replacing my stereo and speakers. So I figured, while I'm at it...You know how it goes.
Anyway, my speedometer is only half illuminated (the left half), so I'd like to replace the lamp, maybe both while I'm at it. The thing is, I can't figure out how to gain access to the lamps. I have the top dash pad removed, but reaching behind to grab the bulb seems impossible.
Any advice?
Thanks in advance.
Any advice?
Thanks in advance.
Re: Speedometer light replacement (joeveto)
You have to come in from the bottom. Drop the column and reach up there. I have to do the same thing. Four bulbs on the both the speedo and tach.
Dropping the column sounds drastic, but it really is a cakewalk.
Remove the plastic cover at base of column.
Remove the two bolts that hold the column "up".
The headlight vacuum override will come out also.
The column will drop down approx 3-4 inches.
Easy.
Let me know if you want a hand.
Stew
Easy.
Stew
Guest
Posts: n/a
After you drop the column it's real easy. You'll see the circuit panel/whatchacallit on the back of the dash. I believe you twist to remove the bulb and holder.. no wires involved. The bulb pops out of the holder.. Easy replacement.
