QuadraBOG
QuadraBOG
The Forum helps again! I searched the archives and found Lars' tech paper on adjusting the Qjet. It took me a while to find the secondary windup screw, but I finally did. Locating the hex screw first lead to look behind the rod holder for (the choke?)
My secondary air valves were flopping around like a fish with NO TENSION. :eek: The hex screw was loose as I was able to turn the windup screw easily before I even got out the hex wrench. Thanks again you Vette geniuses!
:hurray:
:hurray:
