Need help getting Chevy V8 to start
Hi guys, Sorry for the repost, I thought the first one didn't take.
I posted this in the "other cars" section as well since it is a chevy van, but I thought you guys could probably answer my question since your motors are the closest to this one.
I can't get a 1984 Chevy van to start. The motor will not spin. Here are the facts:
The history on the problem is that the previous battery fell into the hood (unsecured) and shorted while driving on the highway.
Starter is a new reman starter purchased after the battery shorted.
I have 2 batteries, AutoZone says they are both good.
When I try to start the van I hear 1 to 3 clicks (solenoid?) and then all the lights go out, and stay out until I disconnect and reconnect the battery.
After all the lights are out, the batttery terminals read in millivolts, not full volts (multimeter). Once I disconnect/reconnect the battery, it reads 12 volts again.
I have continuity (multimeter tested) on the positive cable from the battery end to the starter end.
I have continuity on the negetive cable from the battery end to where it bolts to the engine.
The van is a 1984 3/4 ton with a 305 V8 and a 4bbl carb.
I have not tried to jump start the van.
Any ideas?
Thanks for listening!
[Modified by Square, 2:38 PM 3/25/2003]
Any ideas?
Re: Need help getting Chevy V8 to start (Square)
Sounds like a bad or corroded connection. Make sure all the connections are clean and tight. and make sure the battery is fully charged.
Re: Need help getting Chevy V8 to start (Jvette73)
I agree with Jvette73 - sounds like a bad connection. I had the exact same problem on an '80 350. I replaced the starter and solenoid twice THEN I discovered it was the connector on the starter end of the battery cable that was shakey. It was a hard coating of corrosion that had gotten glossy over time, so it looked like clean steel. It was real tricky and I was quite surprised (that's the humble pie type surprise) that a bad cable eluded ME!!
Really DIG in to those connections and be real sure.
Paul
Paul
I had similar symptoms with my CJ7 and threw on a new starter and alternator. Turned out to be the solenoid. I banged it a few times with the handle of a big screw driver and it started. (bubba fix)
Also sounds like not enough juice from the battery if the lights go off.
The fusible link could be the problem although I blew it on the vette and got nothing at all when I turned the ignition.
Re: Need help getting Chevy V8 to start (midwest-vette)
Thanks for the replys!
I have cleaned the positive battery cable ends, but I do not know where the fuseable link is.
Also, is there supposed to be a relay for the starter somewhere? If so, where can I find that? My Ford van (I know, it's a Ford :nono: :D ) has the positive battery cable go to a small round module on the firewall and then to the battery.
I had the same problem on my work van. Turned out to be the connectors on the battery cables. They looked fine, but when replaced the problem went away.
Good luck... :cool:
Good luck... :cool:
Re: Need help getting Chevy V8 to start (HDIronman)
even if you have continuity on the neg connector i would take a hard look at your grounds including the jumper from the back of the block to the firewall - these took all the heat when the battery hit the hood - the positives were isolated from damage by the direct grounding - dave
