74 timing of manual L48
Last week I set my timing at 12 degrees after installing my mallory system. Thing is, my Haynes manual says that it should be set at 4 degrees, should I have set it at 8 degrees for performance? The engine seems to me running ok at 12 degrees. Should I leave it at 12 or back it down?
Received 4,925 Likes
Re: 74 timing of manual L48 (74 vert)
Initial timing is irrelevant. You need to set it up for 36 total (with vac advance disconnected). At 36 total, your initial will usually come out to about 12-16 degrees.
If you're not having any problems with it at 12º, it's probably ok as long as it hasn't pushed your total timing too high. Keep in mind that what you add to your initial is also added to the total. Generally, total in the 36º-38º range will provide the most power. Going much higher than that can cause power to fall rapidly and in some cases causes serious damage to the engine. A lot of guys are fooled by the increase in low rpm power and don't realize how much total power they actually lost to get it. Ideally, curve the distributor so you can run both optimum low rpm advance AND optimum high rpm advance and have it come in as soon as you can without experiencing any problems like pinging or surging.
The more timing the better until the starts to ping. More timing gives the air/fuel mixture more time to burn in the combustion chamber.
Re: 74 timing of manual L48 (wayne_69_427)
