Modified your motor? Check your spark plugs.
I have the edelbrock performer rpm heads and was useing normal plugs for a 77 350 chevy. Well the plugs were 1/2 inch too short. Check to make sure if you change your heads that they don't need a longer plug now. Mine runs alot better now. :crazy: :smash: :cheers:
St. Jude Donor '09
Re: Modified your motor? Check your spark plugs. (emsrescu)
This is some good advice. I friend changed heads and didn't realize that he needed to also switch to the short plugs....I guess you know what happened first time he revved it....
I also have the same heads and you make me wonder. When you get a chance...what is the length of your plugs.
Thanks in advance,
Marc
Thanks in advance,
Marc
Re: Modified your motor? Check your spark plugs. (Marc80)
You are so right....
I had TFS 23 degree heads on mine for a while and had the wrong plugs in. Way to short. Motor reved great and I had no idea. A friend of mine noticed the problem one day while we were working on the vette. Car had never been on the road yet though for it is in a frame off.
Man was I humbled that day
Neil in Tenn
Neil in Tenn
The manual that came with my RPM heads recommended the longer plugs so I used them from the start. I still had a problem though due to my domed pistons and, until I indexed the plugs, they contacted the domes just enough to close the gaps on those that weren't positioned right.
Re: Modified your motor? Check your spark plugs. (Vetterodder)
AFR had a recommended plug on their web site, so I bought a set as a starting point. From there, only hotter or colder depending on the performance.
So far, so good.
Jeff
So far, so good.
Jeff
Re: Modified your motor? Check your spark plugs. (no_radio)
Not only the length can be different but the seat can be too. The RPM heads state in the paperwork to change to a plug with the gasket seal. The stock plugs were a tappered seal. Edelbrock also recommends a plug number to start with. Sorry, I can't remember what number. If anyone needs it I can look it up and post it.
Re: Modified your motor? Check your spark plugs. (redwingvette)
Thanks in advance,
Marc
Thanks in advance,
Marc
