Holley Carb.Help with ID
Could someone help me identify a Holley carb. The only numbers on the carb are:
1349
L-7456.
I would appreciate any help. The carb will be available forsale , after it is ID'ed.
Thanks
1349
L-7456.
Thanks
Re: Holley Carb.Help with ID (wheelsup)
The only info I can find is the number 7456. Is says it's a 450 CFM model #4360 the primary throttle bores should be 1 3/8" and the secondaries should be 1 7/16". Does that fit with what you have?
Re: Holley Carb.Help with ID (burners)
Burners, the primary and secondary bores are 1 3/8" and 1 7/16" respectively. What would be the application.ie year and engine model.
Thanks for taking the time to help me out.
That's essentially all the info I have. Holley's catalog doesn't give any other details. A 450 CFM would go on a pretty small engine. It may not even be a factory supplied carb. Does it have any funky linkage on it or is it a normal looking carb?
I will throw another piece of information into the mix. I do have a piece of the Delco box that the carb supposively came in.The following numbers are on the box.
0365
07046904 24 33034
The 07046904 is the part #
0365
07046904 24 33034
07046904, 450, 7456, carb, carburator, carburet5or, carburetor, cfm, corvette, delco, holley, hollry, id, identification, install, l7456, list
