Upper A-Arm, Which side is left and which is right???
I dissasembled these some time ago, and have lost track of which is left and which is right. They are back from the shop and re-built... I thnk the the ball joing tilts slightly backward, Does anyone out there know for sure?
Thanks.
Thanks.
Re: Upper A-Arm, Which side is left and which is right??? (Twin_Turbo)
Thanks. It lookd like the longer leg of the control arm is the front on that picute? IS that correct?
Re: Upper A-Arm, Which side is left and which is right??? (kfede1)
The ball joint is offset to the rear by 3/4 inch. Measure the center between the 2 mounting holes and the ball joint falls behind this center point.
