grease nipple on a arms?
Old 03-23-2003, 04:37 AM
szercer
szercer's Avatar
Default grease nipple on a arms?
not sure what I'm talking about here, so if it makes no sense I can post a pic, but the grease nipple on whta I think are the A-arms is very messy and I assume not working, how would I go about fixing this? If this makes no sense I'll do some more research and try again...
Old 03-23-2003, 05:18 AM
BB wowbagger
BB wowbagger's Avatar
Default Re: grease nipple on a arms? (szercer)
Are you taking about the upper and lower spindles? :cheers:
Old 03-23-2003, 07:38 AM
Jvette73
Jvette73's Avatar
Two things can be wrong with grease fittings. 1, They can be clogged which would not allow grease to be pumped in. 2, the checkball in the middle can be frozen or dirty and not return to seat, which would allow grease to come back out. Wipe the gunk away with a rag and scratch it up with a wire brush. Then take a sharp object like a ***** punch and poke on the tiny steel ball in the center of the fitting to see if the ball freely moves up and down and returns to seat. If its too messed up and you cant get it working its really easy to unscrew the old one, and screw in a new one.
Old 03-23-2003, 08:11 AM
Eddie 70
Support Corvetteforum!
Eddie 70's Avatar
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: grease nipple on a arms? (Jvette73)
The grease was so caked up so hard on my 70 I had to use a giant screwdriver and hammer to remove the hardened gunk. :U I got it all off and put new grease fittings in while I had the front suspension apart for rebuild. If you do change the grease fittings, put some caps on the new ones to keep crud out of the new fittings.
[Modified by Eddie 70, 6:20 PM 3/24/2003]
Old 03-23-2003, 01:08 PM
WESCH
WESCH's Avatar
Default Re: grease nipple on a arms? (Eddie 70)
Hi
What type grease is used for this ? Any MIL specification ?
Thanks Gunther
Old 03-23-2003, 01:49 PM
szercer
szercer's Avatar
Default Re: grease nipple on a arms? (WESCH)
thanks that was what I needed to know!
Old 03-23-2003, 06:16 PM
radwebster
radwebster's Avatar
heh heh...he said "nipple"...heh heh
Old 03-24-2003, 02:06 AM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Default Re: grease nipple on a arms? (radwebster)
The only reason I opened this thread was because I saw the word nipple....
Dang where are the pictures??????
Old 03-24-2003, 02:49 PM
NHvette
NHvette's Avatar
... Then take a sharp object like a ***** punch and poke on the tiny steel ball in the center of the fitting to see if the ball freely moves up and down and returns to seat.
Heh Heh Heh ... He said ***** punch.
Why does that induce thoughts of extreme pain ?
Old 03-24-2003, 05:38 PM
Desertdawg
Desertdawg's Avatar
St. Jude Donor '09
Default Re: grease nipple on a arms? (NHvette)
Hummm So he should ***** punch the nipple.....EEEOOOOWWWW !!!!
Old 03-24-2003, 06:17 PM
radwebster
radwebster's Avatar
Default Re: grease nipple on a arms? (Desertdawg)
hahahaha, i think i just regressed to the 3rd grade again :lolg:
Old 03-24-2003, 06:23 PM
Cali,68,L-79
Cali,68,L-79's Avatar
:lolg:
Old 03-24-2003, 06:26 PM
Paul L
Paul L's Avatar
Just clean up the area and replace the fitting. They are about 50 cents. The grease is just chassis lube.
Old 03-24-2003, 06:39 PM
Pedro'74
Pedro'74's Avatar
Hehehe.... One more thread gone bad.... I'm LMAO!!!! :lolg:
-Pedro
To grease nipple on a arms?
Quick Reply: grease nipple on a arms?
