vac advance
Old 03-20-2003, 10:01 PM
jetech
jetech's Avatar
Default vac advance
While checking the timing on initial start up on my engine here is what I found. With vac adv not connected total timing was 40 deg. with vac adv connected it was 58 to 60 deg. How do I correct this to 36 deg total. The main changes I made are a performer manifold, and a mild comp cam. I also pulled the emissions equip.
Old 03-20-2003, 10:57 PM
LAvetteman
LAvetteman's Avatar
St. Jude Contributor
Default Re: vac advance (jetech)
From what I have seen you are right on. 36 degrees is what you want, total timing WITHOUT vac advance connected. The vac advance will bring it into the 50-60 range off of idle but let go before wide open throttle. You can retard your timing a little to get the 36 instead of 40, but your motor may prefer the advance.
Old 03-20-2003, 11:48 PM
Garson
Garson's Avatar
What is your base timing? ( 8 degrees, 10 degrees ???) Your timing spread sounds good, you just may need to retard your timing a few degrees.
Garson
Old 03-21-2003, 04:36 AM
Larry B.
Larry B.'s Avatar
You could get an adjustable aftermarket unit. thes can be tailored for when and how much the vacuum advance works.. Real nice... Cranes makes a complete kit with instructions.
Old 03-21-2003, 11:02 PM
jetech
jetech's Avatar
Default Re: vac advance (Garson)
my base timing is 10 deg.
Old 03-21-2003, 11:16 PM
AlwaysWave
AlwaysWave's Avatar
Cruise-In III Veteran
You may want to get the aftermarket kit mentioned and try stiffer springs.. Look at getting the 36 degrees at about 2800 rpm with an intial of 10-14.
Check the tech tips. Lars has an excellent writeup explaining the whole process.
To vac advance
Quick Reply: vac advance
