Seat Belt Question
Cruising
Seat Belt Question
The metal clasp(right word) is backwards on my seat belt. Ths causes the belt to be twisted when worn. Any way to remove it and put it on the other side of the belt?
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Re: Seat Belt Question (brian7836)
Not that I know of. It sounds like you may have two rights or two lefts or somehow the belts were taken out on put in right. :confused:
If I'm reading your post right, try removing the plastic cover and twist the belt around in the slot it goes thru. Good luck. :flag
