Shifter Adjustment
Shifter Adjustment
I was starting the car in its winter storage location and after it was running I went to exit the vehicle and noticed that when I took my foot off the clutch the enine loaded and the car crept forward. The car was in neutral....sounds to me like the trans/shifter needs adjustment to be completely in neutral...i know how to accomplish this on a Hurst shifter but I am not familiar with the factory setup. 65 coupe 327/4speed (sorry but I am a recently converted ford guy so bear with my learning curve.
Re: Shifter Adjustment (65vette327)
May not have gotten a good "link" when you shifted it out of neutral when parked. I would recommend jacking the car up and manually moving the shifter arms to neutral. Then you can at least drive the car and see if its a real problem or isolated one. Have had to do this with my Hurst until set up right. Not sure how to set up stock shifter, haven't seen mine in years.
Jeff
Jeff
