can you identify these headers?
Hey, a friend of mine gave me a set of headers he wasn't using anymore and I'm wondering if anyone could take a look at these pics I took and identify them for me. He didn't tell me what type of car they came off of, and I'm wondering if they'd fit on my '79 L48, and if so, what kinda are they and what mufflers should I go with? I'm looking at flowmaster 40 or 50 series.
PS: sorry about the poor image quality. All I have is a webcam.
[Modified by SicChild, 12:40 AM 3/20/2003]
Re: can you identify these headers? (SicChild)
I don't have a clue but from the picture top right it looks like the last pipe almost goes straight down. A new set of Hedman headers are not that expensive and you know for sure that they will fit. Something free is not always the cheapest way to go.
Re: can you identify these headers? (norvalwilhelm)
My headers look very similar to yours, but I to do not know what kind I have in mine either.
If you can find any markings at all (letters? numbers?) that would help, like for example if the letters "H O O K E R" are on them :). Otherwise I think headers tend to all look the same. From browsing part numbers, most headers for corvettes seem to be for corvette only, so the chances of these fitting are probably pretty slim. Without a brand and part number all you can do is pull off the exhaust manifold and see if these headers mate up. You might be able to rule them out just by holding them near your exhuast manifolds to see if they are even close. MJ
Re: (MNJack)
EDIT: there are no visible markings found.
[Modified by SicChild, 1:14 AM 3/20/2003]
You could go to a parts store and buy a cheap set of exhuast gaskets and hold them agianst the header to decide if they would fit your motor. If not return the gaskets.
As for the last pipe in picture number two , the extreme right or last pipe doesn't seem to sweep down and back like the headers on my vet do.
The pipe is the one at 6 oclock in the second picture.
Probably for something like Chevelle/Malibu that has the crossmember under the engine, that's why they are swept back.
Get Dynomax coated & do it right. More HP.
Re: can you identify these headers? (Ganey)
Norval, these are for the small-block.
I put a set on mine and soaked the hell out of the manifold bolts for about 2 weeks with PB Blaster. I still had trouble but managed to get the stockers off. Mine fit w/o having to lift the motor but I hear that's a possibility...
