What water pump are you guys using???
I need to change mine,so my first choice is to stay with a stock GM pump...
has anyone out there gone from a stock pump to something else say with a little more flow??? if so what are you using and how did it affect the temp. of the motor??? Thanks :chevy
Re: What water pump are you guys using??? (1bad69)
I installed a factory pump for the car ... and a new 4 row radiator when I put the stroker in. I run 195 degrees normally and if in traffic it makes a squeek above 200. Maybe 205.
I have verified the readings with a Snap-On laser-trigger digital temp gauge. If anything my temp gauge is reading high. :party:
Stewarts Stage 1
It's hard to tell the real effects of just the waterpump as I changed the whole cooling system at the same time.
Cruise-In III Veteran
I just installed an Edelbrock. Haven't driven it yet, but two local guys swear they make about a 10 degree overall difference.
I won't know the true impact because I've also changed out to a DeWitt's aluminum radiator and Spal fans.
Re: What water pump are you guys using??? (SanDiegoPaul)
i dealt with the heating last year and it runs a steady 210 in hot weather...i'm wondering though if i spend the extra cash for a higher flowing pump if it will bring the temp. down anymore??? there is only so much water you can push through the stat. so i am wondering if it is worth it?
i figured most of you would have done more than just a pump, so i guess i might not get an answer...is the edelbrock aluminum???
[Modified by 1bad69, 10:23 PM 3/18/2003]
Before the ZL1 I had a 454 HO crate motor in my car. I had a lot of trouble keeping it from over heating in stop and go trafic during warm weather. When I replaced the OEM style pump with an Edelbrock Victor pump my over heating problems went away. I put over 100,000 miles on that pump and it is still going strong.
Re: What water pump are you guys using??? (ZL1powr)
ZL1powr! your car is off the hook! i'm right down the road from ya...between Charleston and Huntington. Glad to see other WV guys here. :cheers:
I'm using Stewart Stage 2 cast aluminum pump, it works for me...
The difference between stage 1 and stage 2 pump is, stage 2 pump doesn't have any bypass port in the pump casting and therfore has to use a special thermostat with 3 holes drilled in the thermostat to serve as bypass.
Here is the link to Stewart web page it explains how each pump is made.
http://www.stewartcomponents.com/
Ulf
Ulf
what's the difference between the stewart stage 1 and 2's????
http://www.stewartcomponents.com/html/products/waterpumps.asp
Jon
[Modified by Jon69L46, 9:11 PM 3/18/2003]
Replaced with a Flow Kooler & it's been a problem free thus far :auto: .
After my 77 engine build, I didn't want to put the 25yr old pump back on, so I just went with a cast iron Summit brand hi-flow. More GPM and better bearrings than stock and all accessories bolt right up.
Eddie
Eddie
I'm using an Edelbrock Victor pump.
Can't say the pump made some difference since I also had the radiator boiled and repaired to address the cooling system in its entirety. While the car didn't dangerously overheat, it would get a bit hotter than I was comforatble with. Stays right at 180-degrees now even when idling for long periods in the Texas summer heat.
