Chevy High Performance - 200r4 article
In the May 2003 issue is a good article on building a 200r4 for hi-po use, it won't give you all the knowledge to do it yourself but it does have some good info.
Since I've seen a couple people asking about 200r4's lately I thought you might like to get a copy. And I know that if my 700 ever dies I'm switching to the 200.
Re: Chevy High Performance - 200r4 article (C3 Shark Tank)
Yep, I read it. I'm only putting in a higher stall converter and shift kit for right now. When I switch to a motor with some ***** I'll upgrade the pump to a higher vain and the stator shaft.
