Any dyno sheets on 70 454 LS5 engines ???
Old 03-18-2003, 04:10 PM
White 68
White 68's Avatar
Default Any dyno sheets on 70 454 LS5 engines ???
I read the post on the 427 and was interested if someone had one for a stock or fairly stock LS5 454 ....I have added torker 2 manifold/edelbrock 750/ unknown lift Manley cam/ hooker headers sidepipes ...they need jcl baffles from what i,ve read ....anyone thanks in advance if anyone has something ..Tim :flag
[Modified by White 68, 3:12 PM 3/18/2003]
Old 03-18-2003, 08:09 PM
SBR
SBR's Avatar
Default Re: Any dyno sheets on 70 454 LS5 engines ??? (White 68)
This is just a guess but since the net hp ratings started in 1972 the 454 was rated at 270 to 275hp. The 70 version had a higher compression ratio so I would say it would put out 300hp in stock trim.
Old 03-18-2003, 08:20 PM
PRNDL
PRNDL's Avatar
Check out Markus' website (Zwede). It's a 71, but close enuf to a 70. He has dyno sheets stock, and also showing the improvement after several mods. :)
http://www.corvetteforum.net/c3/zwede/
To Any dyno sheets on 70 454 LS5 engines ???
Quick Reply: Any dyno sheets on 70 454 LS5 engines ???
